**EDIT 3/19/2011: I reheaded/relaced the drum today. New photo added. Also shows the rattles I made.
My niece likes the celtic drums I make ("bodhrans") and asked if I could make her a drum for her Indian Princess (YMCA) "tribe." I got some magnolia from BobN last June (he got a bunch from Ed D.... Thanks to both of you!). I decided to hollow out one of the logs into a solid-shell, double-headed drum. The heads are from deer hide (thanks, Kevin/Rhythm House Drums, for the tip on Centralia Fur & Hide... great source/excellent service).
Her tribe has "Raccoon" in its name, so I wanted to put that into the design. I "borrowed" a tribal tattoo design I found on the web for the side of the drum.
So as far as the process: I hollowed out the green log with a drill press and spade bit. It was a nasty job I wouldn't want to repeat.... but it seemed to be the easiest/quickest way considering the tools I have available. Once I was able to hog out most of the wood and eventually penetrate the full depth of the log with the drill press, I used chisels to rough out the rest to about a 1" thick rim that I then let dry for several months.
I then finished it on my lathe. BTW, I didn't try to hollow it on the lathe, because it was way too heavy and bulky. Would have caused my ShopSmith to walk across my garage. Once it was dry though and hollow, I was able to turn it fairly easily.
So, here are some pictures. I'm pretty sure I took some more process photos, but I don't have them handy. Might upload more later.
Yep... It's a whole deer hide:
Cut out two heads and about 16 feet of 1/4" lacing. I'm also making six deer hide rattles for the girls. I'll post those, when they're finished (all parts are ready to assemble... just need a bunch of sea shells to put in them).
The drum can be beat by hand, but I decided to turn a beater anyway. I'm a little concerned about them beating the heck out of the drum head though, so I might not give it to them. LOL
I wound some nylon sting for the grip, while it was still on the lathe. That's more hide lacing wrapped around the head (at bottom of photo).
The finished drum (version before relacing) and beater along with accompanying feathers and raccoon tails (one is somewhat hiding behind the drum).
Really enjoyed the project and can't wait to give it to my niece.
Hope you like!
Hope you like!
