This is a very different spoon than I have ever made before. Just made it up as I went along.
First get a stick of firewood out of the pile and mount it in the lathe.
One end is mounted off center...
The other end is centered.
When you start to turn the off centered end the cuts should start to show very soon.
Start roughing out the bowl and handle.
The top of the bowl is not cut at this point.
Make the handle any design you like and a sort of egg shape for the bowl.
A little sanding on the lathe helps smooth the handle.
Cut away the waste at the band saw.
Drill out the bowl, be careful not to go too deep.
Use bent chisels, scorp or bent knife to hollow and smooth bowl.
I got this bent knife from Ragweed Forge, it is very easy to use and cuts a lot of wood quickly.
It makes smooth fine cuts as well.
Just a little sanding inside the bowl.
And it is done. Now I just have to oil it.
Total time 2 hours 15 minutes and that is stopping to make pictures.
:squirrel:
:squirrel:
