Hi all,
I am still fighting back but need some specific advice. I have a PSI chuck and just bought a Oneway Termite hollower and am doing better but here is a situation I do not understand. I was going to send a picture but I am sure you have all seen this. I am turning from a slice of a log that has been rounded pretty well on my bandsaw. Turning the outside is not that big a deal. My problem is that after I make my tenon and remount it in my jaw clamps, I have not yet succeeded getting it centered. Two main reasons I know it is not centered. I always break through on one side wall whereas the wall opposite is at least half an inch. Also I can tell by the tool bouncing off the piece. At least this explains to me why I am breaking through one side of the wall when I try to get it thinner than about half an inch. So it seems to me that I am doing one or more of the following things incorrectly.
- Not creating a centerd tenon at the bottom of the bowl for my jaw clamps to hold on to.
Although I am not thinking that this is the problem because I do not see how it would be physically possible to make an uncentered tenon when the piece is sitting on a faceplate alone.
There can only be one axis. How could I create an uncentered tenon turning on one axis?
- I am not mounting, or rather remounting, the bowl on the same axis as when I turned the outside. I really try to create a simple solid tenon with a straight shoulder on it of about half an inch but I must be mounting it off its original axis?
So I think my challenge is to learn how to remount a bowl to turn the inside and somehow make absolutely sure that when I remount it it is true, or at least a heck of a lot more true than it was on my last two bowls.
I am looking forward to taking the segmented turning class at Woodcraft in Raliegh and am hoping alot of my newbie questions will be answered there. The termite cutter does work nicely.
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
