I am in the process of making rough sketches/plans for a drop-leaf table, material not selected yet. The center portion will be about 12" wide, the leaves 24-28".
Weight is not a problem, saving space is foremost. Sturdy construction is important.
Would it be better to make the leafs from 5/4 stock or is 3/4 sufficient? 8/4 even?
In the case of either, would you recommend cauls on the underside for strength/flatness?
Thanks!
Thanks!
