Re: The Workbench WORKOUT!!!
Well, I was not going to post another update until I finished... but I'm so jazzed about it that I wanted to share!
I added a couple of spacers with UHMW plastic on the bottom to help keep the twin screw from sagging when it opens. I got the idea for this from a Woodnet member.
Then, while I had it turned over, I went ahead and applied a finish to the bottom of the benchtop. After all, this was the
last time I planned to have it turned over like this!!! :eusa_clap I was very careful not to get any finish on the surfaces that would be glued.
Then I turned it back over
(for the final time!!!! :eusa_clap ) and glued it all up. Sorry, no pics of this... just picture an erector set with every Bessey clamp I own that would reach across the benchtop, along with extended pipe clamps, F-clamps, glue, bolts, sweat, adrenaline... well, you get the idea.
Once the skirts were all glued/bolted on, they had to be leveled with the benchtop. This is where the workout comes in. I planned ahead when I was laying out the joinery (the T&G and all the dovetails) so the skirts would be just a little proud of the benchtop surface. So it was just a matter of shaving down about 1/32" all around... not too much, but still enough to put some heat in the ol' triceps! I used my No 7 and No 4 bench planes for this. Here's a before & after:
Then... more workout. I had to level the end grain of the dovetail joints in all four corners. I used my low-angle block planes for this, as well as for chamfering the sharp corners.
I also had to trim each vise to be level with the benchtop surface as well as the end skirt. I used the bench planes (for the top) and LABPs (for the end-grain) for this also.
So... here's where we stand now!!!
You will notice that I added a row of holes along the front, so I can use dowels to function as a sort of bench slave. They're ¾" diameter, so I can also use a pair of holdfasts to clamp a panel to the front if I ever want to. They were placed so they line up with the supports of the face vise:
The spacing of these holes is the same as the spacing of the square dog holes, but the placement is staggered so I will never have to worry about a holdfast/benchdog collision. :lol:
So, let's see.... still need to do a little more planing, sanding, add the tooltray bottom, apply the finish, and make a handle for the face vise as well as a cover for the twin screw vise. Almost done!!! And just a shade under two years!!!!
