Re: Wine Cellar Project - Completed w/ Pics
Well, I've been busier completing this project and missed posting progress pictures last week, even though I took several. Last time, I posted pictures of the finishes on the African Mahogany (AM) and from that point forward, I worked on finishing the sub-assemblies, applying a second coat of Arm-R-Seal to the WO upper units. Then they were pre-assembled.
Rack Pre-assembly and AM
Pre-Assembled Vertical Rack
Meanwhile, Steve DeWeese has been working on the base cabinets, carefully laying out and cutting the complex half-lap partitions and their beveled ends. In my shop, it was time to glue the 1/8" edge banding to the table top. I found it was flexible enough to bend without steam. I added clamp blocks to the plywood table underside.
First Diamond Bin w/ Face Frame
Table banding Glue-up
Assembly at the client's home began on Sunday, October 8th. Step 1 was to remove a base moulding and to install a 3" riser with 8 leveling feet. Next, the base cabinets were added and screwed down and together. An intermediate top was added in two pieces to provide a dead-flat base for the AM countertop and for the upper assemblies. We assembled the center section and added backs to the two shelf units and the vertical bin assembly. They were lifted in place and, surprise, they fit perfectly (less than 1/2" clearance at each end of a 9-foot wide unit).
Base units in place
End of Day 1
I took Monday and Tuesday off for other activities. On Wednesday, the xenon light system was installed (4 low-voltage 20 watt "pucks" in the shelf units and under the glasses rack on a 3-step dimmer) and the AM sections trimmed to final size and biscuit joined together. The AM was not attached to the plywood since room had to be saved for clamping the three sections together as the glue dried. I did install my new signature medallion (thanks Rick Doby) in the upper side of the left shelf unit (Etched copper embedded in a shallow 1-1/4" forstner bit hole).
AM Countertop glue-up
Signature Medallion
Today, I finished trimming and sanding the countertop banding and gave it a finish coat of Arm-R-Seal. The base cabinets got their second coat as well. And a final coat of Rockhard Tabletop Varnish was applied to the African Mahogany. Here is the final result (I need a fisheye lens to get it all in one shot because it is 9-feet wide and the room is only 7-feet deep!). Needless to say, the client is very pleased.
Left side
Right side
Hope you've found this a worthwhile thread -- I certainly enjoyed doing this project, despite its complexity. Best of all, the client is happy -- enough so that I've been offered another project in 2-3 months to build a formal bar in their basement game room...
