will this work for light work
PChristy
Phillip
3' L x 2' dia Dogwood and BW handle - bored the Dogwood thru did get it exactly
View image in gallery
centered when I turned it around but it does have a snug fit - as you can see on the end it is off a little - I filled it with med CA
ptt49er
Phillip
I don't see why it wouldn't work.
I like dogwood and bw together, too bad dogwood's don't get big enough to make lumber from them!
Nice hammer!
MrAudio815
Matthew
Wow that is very Nice~!
That must be one Massive Mallet at those diamentions~! Almost like a huge club~! :rotflm:
So if the Dogwood is 3' long X 2' diameter, How long is the handle? 5 or so feet long? :rotflm:
Sorry I couln't help myself.
erasmussen
RAS
Must have took a lot of CA.
Looks good, but are you going to go bear hunting with that huge thing, and where did you find a lathe big enough to turn it?
PChristy
Phillip
:rotflm::rotflm: You guys don't miss nuttin - it is 3"x2" the handle is 12" over all :rotflm::rotflm:
Robert Arrowood
Robert Arrowood
I was wondering how you were going to swig that thing:icon_scra.At first I thought it was as big as you:rotflm::rotflm:.
Orta work just fine.
Just don't mash your finger:gar-La;.
PChristy
Phillip
well.... why didnt ya say so?:rotflm: i think it'll woik. why soitinly!:icon_thum
It might be to light - I think on the next one I might leave about half of the through hole empty so that it can be filled with some lead - will that work??
FredP
Fred
shore will:eusa_clap but I believe lead has been determined to be cancer causing in caleefornee.:rotflm: good thing we live in good ol N.C.!:gar-La;
bob vaughan
Bob Vaughan
The CA glue doesn't have a reputation for holding over time. The shocks of tapping on a carving chisel may loosen the joint, but Titebond is easy and quick.
Light is good for wood carving, particularly the older one gets and Mr. Arthur is visiting the hand joints. Heavy mallets drive the chisel further and deeper than I like for good control.
I've got a dogwood mallet I made. It split as the heart was boxed. Even with the split, its still a great and durable mallet.
For driving the shaft out of an 18" planer, maybe something heavier.
PChristy
Phillip
I didn't know that - The next one I make I put the TiteBond to it = thanks for the heads up on the glue
