I'm making a couple of fairly simple portable tables from some free plans that I'm going to enlarge and think I need to deviate from their suggested mounting hardware and am not sure what I should use.
The top is just a 3/4x11 3/4x19 1/2 ERC plank that will have some holes and slots to hold wine glasses. I'm going to use a small diameter trunk section of Cedar as the single leg. The plans call for a premade table leg to be attached by using a straight top mounting plate which attaches to the bottom of the plank via 4 screws. I'm making them to be used on the beach so they'll be exposed to some moisture and salt air so I'm guessing I probably should use stainless hardware but I'm not sure I'll be able to locate the plate they use in stainless.
I was thinking of going with 5/16 hanger bolts and matching T-nuts in stainless but thought I'd see if anyone else could offer any better solutions and maybe a local source since I'm pressed for time on getting the hardware. WoodCraft doesn't carry stainless and I'm going to try Klingspor tomorrow but I'm not hopeful. I think McFeely's carries them but need to go over to their site and double check.
TIA.
TIA.
