I want to build some shop cabinets. Nothing too complicated - face frame, drawers, doors. But, I do want them to last a while, and since it's MY shop, I want them to look good too!
I'm going to need quite a bit of plywood. I have not been terribly impressed with the hardwood plywood here at Lowe's or Home Depot. Occasionally there is a really good batch (the HD in Apex had some red oak ply for a while that had ZERO voids), but it's too much of a hit-and-miss. And at $50/ sheet, it's not exactly a bargain either. Someone mentioned some "shop grade" white oak plywood a while back, but I can't find that thread. That sounded like a good fit for what I'm trying to build. Another thought would be to get prefinished plywood that's used for kitchen cabinets. Considering the cost of finishes (even standard poly), buying prefinished makes more and more sense. Are there any local stores that carry prefinished ply?
The last consideration is actually getting it to the shop. I can't haul anything larger than 4'x4' in my car. Cutting full sheets in half works OK for smaller projects, but with 8+ cabinets, that would cause a lot of waste. So delivery would be a plus.
The second question is about drawer slides. I have a couple of boxes of 18" full extension drawer slides that would be perfect for this project. What is the best way of mounting these in face-frame cabinets? I've seen the method of using a bracket in the back of the cabinet and then screwing it to the face frame, but (a) I'd have to buy these brackets and (b) I plan to make some of the cabinets 24" deep to have a larger work surface. I could run a rail inside the cabinet at 18" to attach the brackets, but that seems like a lot of work. The other option would be to build up the side of the cabinet so it's flush with the face frame. Basically a piece of scrap 18" long and ~2" wide. That's a lot simpler, but a lot of extra material.
