I am starting to have issues with my planer. It is a Powermatic 209HH - a 20" Chiwanese planer with a Byrd shelix head. I know of at least one member who has the same type of unit, but I think his head has straight knives not the carbide insert head.
I will say up front that I changed the feed rate of this unit. It came with the gears and the chains to make it feed slower. I have checked the unit and at no point do the feed rollers ever stop turning.
It worked pretty good when I first got it, but seems to have gotten worse. What it is doing is that it is not feeding boards well. I have to consistently push the boards through the planer. They get stuck/stop. Also, as short boards (18" or so) come out of the planer they tilt up and then "slap" the table. Lastly, i have around 3 inches of snipe on the rear end of the board around 1/64" to 1/32".
The springs for the infeed and outfeed rollers were tensioned way tight. I loosened up the tension a lot, but it didn't make any difference. I got my straight edge out and aligned both the infeed and outfeed tables. No change.
The bed rollers are set flush to the table, and since I use it for finish planing as well, I don't see the need to have them above the bed. I checked the belts and they are not loose so no slipping there.
Doug Robinson suggested feeding boards on 1 side of the unit or the other to see if it was out of alignment on 1 side. It feeds horribly on both sides.
So, I am thinking I am going to need to check the height of the pressure bar and/or chip breaker may be to low and causing too much friction/resistance. Getting this checked and adjusted will be a royal PITA as it is not a simplistic or quick undertaking. If I go through that, then I am going to check the infeed and outfeed roller height as well. Again, not pleasant.
Anyone have any other suggestions/thoughts that I may be overlooking before I take the steps that I really hope I don't have to take?
