My latest shop project
Vetteman9956
Brad
As some of you know, I picked up a Unisaw real reasonable this summer. It has taken much cleanup as it had been stored in a shed for a few years. I tried to find a way to use the open space under the table. I came up with this and it will store all of the saw accessories. Bottom right drawer will hold 10 blades and I made the shelf to hold the fence yet still be able to turn the angle adjustment and open the drawers. I still have to build a base for my Bench Dog cast table since it won't fit where it does on my contractor saw due to the unisaw being a left tilt. Also got a shark guard and it stores in the upper right hand drawer. The upper left drawer holds push sticks and wrenches. It's made out of Maple and added the Walnut to break up the front. Open space in center is for base caster access.
View image in gallery
Vetteman9956
Vetteman9956
Brad
Don't have the table on yet but by the time I get it and the Bench Dog router top added, it already will stick out beyond the end of the 52" rails. If I went much further, it would be like an aircraft carrier and I would have to crawl over it to get anywhere in my shop
LeftyTom
Tom
Nice work, Brad. That walnut accent is way too nice for shop use. :eusa_thin I am sure you will find something suitable to make a Ts extension, when the need arises. :thumbs_up
JimmyC
Jimmy
Brad,
That is a fantastic cabinet ! I have a Jet cabinet saw on a Delta base and I love the base, I've been trying tofigure a good storage cabinet out and this looks great. I have two question though:
1) How tight is the clearance when using the wheel on the right side ?
2) How tight is it when you engage the lift lever on the mobile base ?
A day late, and a dollar short - Delta makes a foot peddle for some of the their mobile bases that is off set. With a little welding, and some rod stock, you could bring foot peddle for caster out either front or rear of cabinets. Nice job on the cabinets.
RandyJ
Randy
Dang Brad! That looks better than the cabinets in my house!
Great job. :notworthy:
MrAudio815
Matthew
Very Very Nice.
Love the Maple & Walnut, not sure I am that fancy. Or that good to make something that nice. Great Job~!
When I make mine, it will probably be out of MDF, have a bunch of that stuff.
And will probably put casters on mine as my saw has caster's built in. Hum I wonder how much room I will need to engage the side wheel to lower the casters, don't want to have to pull out the storage every time.
