Last night I finished assembling my first shop-made lathe tool. I decided to copy the "EZ Rougher" design, both for the effectiveness of the tool as well as the simplicity of manufacture.
And the best part was, it only cost me $1.60 to build!
I started with a spare carbide insert and screw from my jointer planer. Next, I headed to the steel pile for a 12" piece of 1/2" square bar stock. I cut a notch for the insert, drilled and tapped it for the screw, and then used my belt sander to polish up the rough finish of the bar stock.
Don Patterson (Touchwood) was kind enough to give me an assortment of wood suitable for tool handles, and I selected a nice piece of 8/4 QS Sycamore for the handle.
My only expenditure was $1.60 to Lee Valley for the brass ferrule. I had previously made one from a piece of brass pipe for another project, and figured that for a buck sixty it was worth it to buy one that was pre-made for this project (and I prefer the look of brass over copper).
After drilling the handle with a 1/2" drill, I used torches to heat up the end of the bar stock to burn it into the handle. A little epoxy, and voila, I have a new tool!
Many thanks to Doug R, Doug W, Charlie, Don, Rob, Nate, Gary and others for sharing their wisdom and advice re lathe tools.
