After watching the Woodwright's Shop episode on the Elizabethan-joint stool, I decided to give it a try. Ended up with this:
The week of Thanksgiving, I split out an oak log (tree dropped in Sept) with maul, axe, and wedges to get some segments that looked like this:
Then took the froe I bought earlier in the year to split off the juvenile wood center and sapwood outer rings. Found out that a froe works a lot better with a froe break, so had to build one:
Learned how to use the axe and froe a bit differently in truing and rough-squaring the billets:
Ended up with some roughly square stock which I then rough dimensioned with the scrub and try planes:
After it dried some, I planed to size, chopped mortises and cut tenons with chisel and saw: , used a drawknife and spokeshave to shape legs (stiles) ,
and used drawknife, chisel, and block plane to make the pins that hold it all together .
Then I fine tuned the tenon fit, and drilled the holes in the legs (Sorry about the blurry picture). I then marked the hole location in the tenons and drilled them offset by about 3/32". (Sorry again, no picture)
Then I assembled it by driving in the pegs. Amazingly it came out quite close to square (one leg off by 1/16th" .
I don't have a good piece of riven wood for the seat at this time, so I made a temporary out of a slab I chainsawed last summer (the chainsaw was the only power tool used in any of the process from tree to stool)
A really fun project in which I got to play with the majority of my hand tools, develop some new skills and really hone some prior ones. After it dries a bit more and the weather warms up, I plan to give it a couple coats of linseed oil.
Thanks for lookin'
PS: More pics in my photo gallery in both the "Stool" and "Riving Oak" albums.
Thanks for lookin'
