Finishing a table top...
pslamp32
Peter
Quick question, do you guys/ gals put a seal and topcoat on the bottom of a coffee table top? Thanks! :)
User not found
Yes -- you need to seal it to insure that the wood does not warp due to moisture entering the wood unevenly. Add the finish, too.
pslamp32
pslamp32
Peter
Thanks. Can It be done after the top is finished so I dont have to flip back and forth? It's not attached yet.
Howard Acheson
Howard
It depends on how the top is attached to the support and leg assembly. If the table has a surrounding skirt under the tabletop, finishing is not necessary to assist in warp prevention. The support mechanism will give it all the support necessary. However, if the support assembly is minimal like trestle table, then finishing the underside is desirable to equalize moisture penetration time.
My general rule is to stain it an put one coat of finish on it unless it fits into the second catagory above.
