Finished it up today.
The frame is maple and the finishing of the work sounds like a lot but was pretty simple. I sprayed the entire piece with a sharp mix of shellac, two coats. Not much build but sealed it well. A honey maple stain and tone lacquer was sprayed on the frame to age it and to separate the frame from the panel color wise. A neutral Liberon wax was applied to the entire panel and buffed. I then made a custom colored wax using neutral and walnut colored wax. This was applied to the entire panel as well. Using steel wool, I buffed the pig clear of wax and then hit the high spots on the blanket. This created more depth and contrast, it also cut all light reflection off of the pig. The entire thing was then buffed to varying degrees. All this was subtle but made a difference in the look. Sorry my photographic skills didn't pick much of that up.
It was a lot of fun and did not break the bank time wise. Hope you enjoy...all comments welcome.
www.stromcarver.com
www.stromcarver.com
