The continuing saga for cutting my first Dovetails . . . . .
I went out today and bought a Jasper Adapter plate for my Bosch router. I should have opened the package in the store since I was smart enough to bring my router and the existing baseplate (dumb move). Anyway, the gentleman helping me is very nice and takes my existing baseplate, matches up the holes on the packing and says: yep, this will work - the holes are close to lining up and the center of the plate is close to the center of the router. I've now learned, the key word in that sentence was CLOSE. Close does not appear to be good enough when it comes to cutting dovetails.
I had already set up the dovetail jig this morning, so when I get home with the base plate, it is an easy install and I'm not long before making sawdust. I do notice that the bit is not in the center of the adapter but no matter how much I play with it, there is no way to get it centered. What the heck . . . . lets give it a whirl and see what happens.
Well the first pass goes just as expected. I am only using MDF so there is a little tearout on the front board but nothing that would affect the fit of the DT's. Everything looks good but I quickly notice that the DT's are not cut in the exact center between the guides of the teeth on the jig. At this point, I'm confident they will not fit together but I decide to check anyway. Sure enough, they are about 1/16 overlap and there is no way for the boards to connect. I did notice however, that my depth of cut seemed to be perfect (a small positive to take from the experience :eusa_danc )
Not worried about ruining the boards, I decided to put the boards back in the jig (and btw, the PC jig is great for alignment of the wood and the offset - everything seemed perfect) and rotate the router 180* so that the bit can even out the cut. Obviously this won't work perfect, but it's worth a try. To make a long story a little shorter . . . . . here are the pics of my first half-blind dovetails. My decision is now complete - the current bosch router will be my router table router and I'll be off to the store to buy a router to work with the PC jig. The only for sure thing I know about woodworking at this point is that - when you don't know the answer, the answer will somehow include buying a new tool . . . . . :icon_thum
