Blade storage box w/ pics (WIP)
WNC_Dave
That looks like a good storage option. maybe make a small one just for the dado blades so you can take it to the saw when you are setting up for a dado, instead of taking the larger box with blades that you are not using.
Dave
lottathought
Michael
I had been thinking about this problem for a while. I had not come up with anything this nice however.
I might have to borrow from your idea.
cpw
Charles
Looks great. Hope it serves you well. Wouldn't work for me, though. All my tools take different size blades:
TS = 9"
CMS = 10"
CS = 7 1/4"
Cordless CS = 5 1/2"
waltv
Walt
I built the box shown here from sketched plans in the Tips section of some WW magazine. But I can't remember which magazine!
It's made from some plywood, pine and hardwood scrap pieces. Pretty simple to built. It has 10 drawers or trays to hold blades. (In this case all ten inch blades.)
Keeps the blades separated and isolated, so you don't skin up you hands on the teeth of adjacent blades.
Ray Martin
Ray
Walt,
That chest of (blade) drawers really does look nice... and it answers the challenge of different size blades. you could even store spare jointer blades in a drawer.
Ray
Alan in Little Washington
Alan Schaffter
Both solutions look good! They both raise issues I want to incorporate into the cabinet I have been thinking about building under my TS extension table to hold blades, jigs, push sticks, etc. etc.
I am thinking of making a blade drawer similar to Jay's box, with the blades standing on edge, so I can see all the blades at one time, but build it so it that tilts out.
Also, I am thinking about putting a radius on the tops of the dividers that is slightly larger than the radius of the blades so the tips are slightly below the tops of the dividers, are protected, and my knuckles are protected :) . I would probably need two sections- one for my 10" TS and CMS blades and another for my 8" dado blade and chippers.
Since the blade tips would be below the dividers, I would bevel an area of the that angles away from the blade, on the inside top edge of both adjoining dividers so I could grab a blade and remove it. These beveled areas would need to be in different positions on the dividers, blade to blade, otherwise the bevels would cut into each other and you would expose the teeth of the adjacent blade near your knuckles.
This method would allow me to see a section of the blade/teeth to make my blade selection and allow me to put my fingers in to grab and pull out a blade without my knuckles hitting any other blades. Clear as mud? I wish I was good at Autocad or Sketchup!!!
sawduster
Robert
J,
You can throw that box my way if you want to throw it out :rolf:
Man. that's way better than I could build .
Couple of hours ? It would take me a couple of days to even figure out how to cut the pieces :lol:
I like it !
Alan had me lost by the 5th sentence of his post :drunken_s
waltv
Walt
Jay,
Don't do that! Your setup is OK. Functional and straight forward. The case I built wasn't my idea!!!!! But, I did like the isolation of the blades from each other though.
By the way, I store my blade case on a shelf in a roll-around cabinet in which I store other TS accessories like dado set, tenoning jig, wrenches, throat plates, etc. It is too heavy with 7 or 8 blades in it to lug around the shop very much. The roll-around also acts as an additional outfeed support occasionally, so it's generally close to the TS.
