Thanks to Mitch (Amish Warlord), his truck, his back (sorry!), and Tony's Genie lift I got my new (to me) Delta 28-475X bandsaw home on saturday. I spent the rest of the weekend trying to get a 3/4" x 3AS-S timberwolf blade set up on it for cutting a few turning blanks. No matter where I put the blade on the wheels, it climbs its way to the edge and stops once the teeth are off of the tire and over the wheel taper. I took the riser loose (after a couple of trips to Harbor Freight and Sears to get a 1 1/8" wrench and later a 1 1/4" wrench when I figured out that the nut on the 3/4" bolt was a heavy duty nut... :BangHead: ) and made sure the wheels were aligned and coplaner. I played with the tracking adjustment which works by using a set screw to adjust the angle of the upper wheel. No matter what I do, the blade works its way to the edge of the wheel. I would let it run in its "happy place", but at the edge it hits the clip that hold the lower door closed and makes a horrible noise too! :confused_
Does the alternate set tooth pattern of the blade pull the blade to the edge of the wheel? Is there a way to try and center the blade? Should I reduce the blade tension? Any help would be appreciated! Here is a pic of the blade in its "happy place" (sorry for the cell phone pic!!!!)
