Anyone tried Rockler's Power Bore bits?
merrill77
Master Scrap Maker
Anyone tried these bits? The review on their site seem positive, but I'm curious if anyone here can confirm or deny their claims?
TIA!
JackLeg
Reggie
Yessir! I own a set and they are the fastest cutting, least clogging bits I've EVER used. :icon_thum One caveat, they are really made for use in a drill press where you can control the depth.
If you use them in a hand drill, be prepared to cut faster than you've ever experienced. Control can be a problem. The small bit, 1/4", will wring itself off if you aren't careful.
Worth the money, IMHO! :wsmile:
timf67
Tim
+1 on the drill press. I tried using a 3/4" by hand and had a lot of issues. The majority of the flute is a smaller diameter than the tip. This helps it cut faster but difficult to control.
CatButler
Bryan
Here's a little secret, they also do pretty well in bit braces. They sharpen somewhat like the auger bits too. The 1/4" tends to be a bit flimsy though.
merrill77
merrill77
Master Scrap Maker
I was thinking when I watched the video "they look just like my auger bits". And I like how those cut when they are sharp. If the squarish-shank auger bits would fit in my triangular drill chucks, I'd probably be using then in my press already! :wsmile:
