I have some birch 1/4 plywood that warped slightly due to the heat in my shop. I was wanting to use it for paneling on cabinet doors. The cabinets will be painted white so I am using birch panel with 2" styles and rails (with a grove down the center to accept the panel). I cut the panel to size hoping the warp would be out of it and there is still a slight warp in one corner.
When I did the dry fit, I could tell that the warp in the panel forced the styles/rail to bend slightly. With the slight warp, the door will not be able to shut properly.
Now that I have given you the background....
Is there a way to get a slight warp out of a 1/4" panel? I have other paneling, I just don't want to be wasteful.
Thanks!
Thanks!
