I'm working on a fireplace surround and mantel and will be making the mantle out of walnut. Problem is, the mantle needs to be 9 - 1/2 or 10 inches deep, 72 inches long and 2 inches thick minimum. You'll be able to see the top and portions of the bottom. I have a stock of walnut in different thicknesses and widths that are certainly long enough. However, I don't have any that are 9 - 1/2 or 10 inches wide. The thickest boards I have are 8/4 rough cut.
Has anyone tried gluing planks edge to edge as well as on top of each other to get a block thick enough in this length? I could glue like a long cutting board with the boards standing on end-grain but that doesn't exactly give the look I want. I could go buy a slab thick enough to use in one piece but that would be expensive and seems silly since I have around 500 board feet of the stuff in my shop. I'm thinking of planing 4 boards down to about 1 inch thick by 4 - 1/2 inches wide, and then gluing the 4 together to get my thickness and width. At that point, milling a trim band to go around the edges and hide the seams so that it finishes off the slab.
Has anyone tried this and what success or failure have you had? I know expansion and contraction is a concern but it will be free floating off the front of the fireplace surround and only attached near the back. Thanks for any comments, suggestions or words of experience.
