Finishing 101 with Fine Woodworking's Gregory Paolini
Asheville Hardware
Asheville Hardware
There is still two spaces left for the Finishing 101 with Gregory Paolini this coming Saturday.
Here is the class description:
"Having good finishing skills make all the difference between an OK project and a phenomenal one. In this full day, hands on, finishing workshop, students will learn about various finishes available to the woodworking enthusiast, their pros and cons, and easy ways to apply those finishes. We’ll remove the mystery that shrouds the uses and compatibilities of the common woodworking solvents and finishes, and we’ll examine surface preparation for successful finish application as well as pre-finishing techniques. Students will also learn how to combine dissimilar finishing materials in to the same project, literally allowing them to mix oil based and water based components. Plus, Gregory will share pro-shop tips to ensure fantastic results, and field an active Q&A session with students throughout the day. A lot of information packed into a full day - Bring a pad and pencil to take lots of notes!
If you've been struggling with finishing, and are unhappy with your finishing skills – Or are still searching for that elusive “silky smooth as glass” finish, this hands on class is a must for you!"
The class runs from 10am-4pm
Cost is $135.00
If you are interested, give us a call at 828.252.8088 to reserve your spot right away.
