Far too many months ago when I built my shop I constructed a closet to eventually house my compressor and DC. Today I finally finished the DC piping installation.
The closet has an exterior metal foam core door with the weatherstripped side facing the closet interior for sound control.
Where the original window was I have installed double sheets of fiberboard with a small air gap in between for sound control. On the interior side the bottom half has been cut away to allow air pressure generated by the DC to escape by flowing between the sheets of fiberboard. This allows for relief but also absorbs sound.
On the exterior of the door, the top half of the fiberboard has been cut away and I constructed a filter box with melamine coated pegboard air baffle to house an air filter so that any dust escaping from the 1 micron DC filter bag is not returned to the main shop.
The filter is a 16x20 Merv 12 rated 4" pleated paper high efficiency filter made by Honeywell. It is housed behind a sliding BB panel.
Delta 50-760 housed in the closet with a short length of flex hose connecting it to my 4" PVC shop piping. The DC is controlled by an RF remote.
Start of the pipe run exiting the closet.
East - West main trunk with the hose to my tablesaw connected. The yellow end cap is temporary until I obtain another blast gate and another drop will be installed at this terminus. The wide turn wye to the North - South line is visible.
This is the North- South line running across the shop. This line has another drop installed in the center portion of the shop, one for the RAS, and one angled for use with the drillpress. Also visible is my Jet air cleaner which does a fantastic job of keeping stray dust under control. Barely visible just in front of the Jet and just below the light is a 4" pipe in the wall which terminates outside in a louvered vent. Eventually this will be piped to a ceiling mounted exhaust fan box similar to a bathroom exhaust fan to suck out particularly nasty fumes from finishing etc.
I am pleased with my installation and it seems to be doing everything I expected from it. :wsmile:
