Veneer Tips?
JackLeg
Reggie
When you apply thin strips to shelf edges (for example) do you usually mitre 45's on the corners or just make butt joints? I have NO experience with this and am trying to finish up some shelves for LOML birthday today.
HELP! (and quickly, please!) :notworthy:
JimmyC
Jimmy
Reggie,
If it's real thin, like iron on veneer edging, I butt joint them doing the front edge last so that it's hardly seen. Anything thicker, I miter.
Hope it helps.
Jimmy:)
JackLeg
JackLeg
Reggie
Reggie,
Hope it helps.
Jimmy:)
Thanks, these are actually 1/8" strips that I made by cutting them off the edge of the same boards I used for the shelf unit. Guess I'll give the old Bosch SRAS a try!
JackLeg
JackLeg
Reggie
Thanks Jimmy and Dave. Mitered the upper corners and they look pretty good for a JackLeg! :-D
Jimmy, I used contact cement to save time. Seems to be OK.
Got one coat of poly on, waiting for drying to put on the 2nd coat. Made a back from 1/4" MDF and plan to shoot it on with my brad nailer, and that should do it.
Should have it in the house tonight for a late birthday present. Pics later.
Thanks to all who responded. You're the best!:eusa_clap:eusa_clap
