OK, so I worked on this some yesterday and today I set up and installed a new construction house of cabinets, which I’ll trim out tomorrow morning. Now I’ve had a little time mess with the pictures so here we go.
like I said it’s boring work.
so I bored from both sides the hole for the mortise for the beams first.
now for the chisel work
and now we can see what happens when you forget to clean the debris from the bench often enough.
and now we will bore the wedge mortise, I used a scrap piece as a beam to prevent blow out inside the beam mortise. Only eleven from both side.
that’s far enough for now. I’ll get back to this later in the week. I did finish the first one and if you look carefully its in several of the pictures, I also used it to do some of the marking out on the rest of these.
