My right tilt 52" Unisaw and Unifence has the end of it's side table butted up against the approximate center of the long wall of my 14 X 26 shop putting the saw itself roughly in the center of the shop. I don't break down full sheets inside the shop, but I couldn't bear to cut the fence rail down to 32". All traffic goes around the other end of the saw, but that's where my 6" joiner is. A bench is against the opposite wall with my miter saw on it, so the space between the joiner and miter saw bench is about 26". A multi use workbench is behind me when I'm using the Unisaw, and it doubles as an infeed table for longer rip cuts. I have a 3 X 3' attached outfeed table on the saw that folds down when needed. Everything else is located against the outer walls of the 3 remaining walls without the saw against them. It's tight, but I've been managing, as I'm the only one in the shop 98% of the time.
Charley
