I picked up the new (old) spindle sander I won on Ebay, in Wilmington on Tuesday, but since it has been raining here ever since, it sat in my garage for the last three days. I finally hoisted it up to my shop earlier this evening.
The machine is a Max OVS-1 oscillating spindle sander. The serial number is VS2908 which I believe makes it a 1980 or newer machine. It has a 24" x 24" cast iron table, rack and pinion tilt mechanism, integral spindle and insert rack, a 1725 RPM 1 hp motor, 75 oscillations per min. , a 1-1/2" stroke, and weighs 350 lbs.
It looks mechanically sound and should clean up really well. The motor is three phase. I didn't get around to testing it with my VFD, but I turned the spindle by hand- it turned freely and oscillated smoothly. I have a spare single phase motor, so don't know if I will use that or run the supplied motor with the VFD.
The top is covered with light rust, but that should come off with minimal effort so it should look like the little test strip I cleaned. The pedestal is covered with grease and dirt, but the paint underneath looks good. I haven't decided if I will paint it gray to match most of my other tools. It is missing the switch with is of minor concern.
It came with only 1 insert plate and the VSDC1 dust system adapter- but that looks very inadequate. I got almost the full 10 spindle set- 4", 3", 2", 1.5", and 1" rubber sleeved spindles and 3/4", 5/8", 3/8", 1/4" steel shaft spindles. I am missing just the 1/2" one. It also came with a 4" inflatable bladder spindle though I don't know yet if it will hold air. There is also a smaller 2" bladder spindle body but it doesn't have the rubber bladder.
The only problem- the 3/4" spindle is stuck in the chuck. I suspect the Morse taper and/or the threaded section below that are rusted fast in the chuck. I sprayed WD-40 on it and applied some serious torque with some big wrenches, but couldn't break it loose. I have another thread penetrant I'll apply and let sit overnight before I try again. Anyone have any other suggestions?
The bottom line, if I can remove the spindle, I think this classifies as a gloat- an oldie but goody, top-of-the-line spindle sander for which I paid about 1/10 the price of a new one! :eusa_danc:eusa_danc:eusa_danc:eusa_danc
