Sanding small items
kelLOGg
Bob
I cut several small (~4" dia) cherry cookies which I need to fine sand to remove drum sander lines. My palm sander is 5.5" dia so I had no way to keep the cookie from rotating while sanding. I purchased a sanding pad which still allowed the cookie rotate so I returned the pad an hour after I picked it up.
Question: What kind of pad do I need for such a small cookie? The one I ordered from Amazon had no specifications listed. When I received it, the word "medium" was on the package. I don't know what that means or what other options are available. Ideas?
Berta
Berta
I make a lot of things that need sanded. Some small, some big. This is my sanding jig. I use this for fretwork as well as solid work. It does allow the wood to move a bit, I use an orbital sander. The router pad is not very tight. I don’t have problems with lines or breakage. It’s made from a finished piece of 3/4” shelf, a used bit of router pad and a leftover bit of threshold. Everything gets sanded on this.
You can also make a circle of masking tape sticky side out and try that.
bob vaughan
Bob Vaughan
On a couple of occasios, I've gently clamped the ROS upside down in the vise and held the small part to the spinning disc. It wasn't perfect but It did work well enough.
kelLOGg
kelLOGg
Bob
Ok. It surprises me that some kind of material is not available but you all have given me ideas. I will try a spray adhesive on some surface.
RobS.
Robert Slone
I've done the same thing Hank suggested. I mounted my belt sander upside down and sanded a bunch of coasters I had made. For cutting boards I did as Chris suggested and used the same clamps.
JohnnyR
Use a fostner bit in some scrap and place the cookie inside, will still get some rotation but should work.
Wiley's Woodworks
Wiley
+1 for Chris' approach. Make a one-time shim slightly smaller in diameter than your cookies that makes the cookie sit ~1.2" proud of the jaws, and place it under the cookie. Keeping it under your workpiece will support the workpiece without having to crush it in the clamp jaws.
Double stick tape should work just as well. Make sure you get tape that is intended to be separated, not carpet tape. That's what leaves a residue.
kelLOGg
kelLOGg
Bob
I still think I will go with double sided tape or shelf lining. The cookies are only 1/4” thick (failed to mention that) so I don’t want to clamp them.
