Right height
PChristy
Phillip
Turners - what do you recommend for the right height for turning on your lathe - Scroll saws should be at elbow height - is that about right for the lathe
Re: Right hight
That's what I've read, the spindle should hit about your elbow. I've never actually measured mine though.
TracyP
Tracy
Re: Right hight
Good question Phillip. I will have to watch this thread. I now have turner's elbow (if there is such a thing) from turning a large vase this weekend. Ask my brother next time you see him to show it to you. It is big.
PChristy
Phillip
Re: Right hight
I was wonwering if this was right because my back sure has been hurting - I don't know if it is from working or from the turning - I will check it this weekend and see what I have - I don't know what I am going to do if my son ever starts turning - he is 6'5:swoon:
TracyP
Tracy
Re: Right hight
Get him a stool so he can sit down,:gar-Bi
I'm 6'3" and I had my HF lathe set at about 43½" at the centers. It's a short lathe, I got there with 3 layers of twobasixes or 4½" of solid high quality pine. My new ShopFox lathe came in at that height less a ½" and has felt comfortable to me.
I would shoot for centers at elbow height as a good place to get started.
erasmussen
RAS
I just went and checked mine. with the wheels and all its at 46".
wonder if I could do better if I lowered it some:icon_scra
But then I wouldnt be able to move it:no:
Trent Mason
Trent Mason
I know it is supposed to be elbow height. Mine is still sitting on the floor. I'd like to build a mobile base for it, so hopefully that will raise it up a little. My back gets worked enough at work, turning a bowl is just the icing on the cake. :swoon:
NCTurner
Gary
Jan Woodturning Mag had a write up on this.
"Stand with feet apart and relaxed, lift your right arm from your elbow only to a position level across your body. Measure from the distance from your elbow to the floor. The lathe center should be at this height"
To tall make a platform, to short raise the lathe.
