There are many ways to plow out a groove - certainly you have choices! I like to use tools for whioh they are well-suited to do a particular job. Nothing is wrong with using a router to plow out a dado and it is done all the time. I just find it oftentimes is "less filling." My experience when building drawers and plowing with a 1/4" bit has been that the bit can wander slightly, even with the workpeice well supported and braced on a router table, and as well you must feed slowly due to the size of the bit. It is also susceptible to clogging in the cut. For these reasons I rarely use one for this purpose anymore, but if so primarily when making small boxes where the length of the dado is not overly long. For me, the better path is to use the dado blade on the TS. The groove is almost always smoother and very straight. I realize this defeats your intention of trying to avoid changing blades and that may make the suggestion less attractive.
BTW - be sure your plywood is actually .25" and not 5mm! If it is the latter it will not fit in a groove cut with a router bit of the former size. Another factor in favor of a dado blade ...
