Tried this approach and experienced more kick back than I have ever had with my tablesaw. I might need a lesson..... I can't see m to get the hang of when to stop a regular and start a climb cut to reduce tear out. It got so bad yesterday that I feared for my hands!!
Just an FYI: If you are using a table mounted router for your final templated (aka 'jig') forming/tracing, you should install a Starter Pin in your router table to provide you with a fulcrum to improve control as you lever your project into the router bit. Once you make contact with the router and the guide bearing is resting on your template (jig) you can slowly back off the starter pin and carefully trace the outline of your template AGAINST the rotation of your router (assuming you are using the front of your router table, that means from right to left -- just like any other job on the router table -- if you switch at some point to using the rear face of the bit, then the relative direction switches, but it should all be a single continuous and (ideally) uninterrupted motion throughout the tracing of your template's contours.
Also keep in mind that in templated pattern routing you are typically just nibbling away a fairly thin section of wood outlining your project (e.g. you've already cut away most of the excess with a scroll saw, band saw, jig saw, fret saw, coping saw, etc.). Whatever is left to be cut away should be no more than 1/3 the router bit's diameter (for 1/2" pattern or flush-trim bit, that would mean less than 3/16" in a pass). If you cross the 1/2 diameter point you will notice that your project becomes more difficult (though not impossible) to control.
For small projects USE GREAT CARE. Always ensure that, even if you get kickback, your hands and fingers are not located in such a way that they might get drawn into the bit!!! Use push pads, sacrificial boards, or whatever other such implimentation that you feel is necessary to ensure your safety. If using a homemade jig to hold and control your template (e.g. handles mounted to the template or otherwise) DO NOT USE STEEL SCREWS OR BOLTS -- use aluminum or brass (solid brass, not brass-plated) screws, bolts, washers, or nuts. If your router bit (especially carbide router bit) strikes a steel screw or bolt it will likely shatter and self destruct, if it hits brass or aluminum it should simply cut the screw or bolt without damage. The same advice applies to your other cutting tools as well, steel hardware equals damage to blade, brass and aluminum equals safe for blade.
