One of the largest pines I have seen..
paulross
Paul
This is my first attempt at posting pictures in this forum, so bear with me. Here's a picture of a field pine I felled a couple of years ago on our property. Small end 32" on the big log; recovered 6 12' logs. The tree died because of drought. Coincidently, the ring count also gave a birth year of 1835. For some reason this tree was left standing throughout successive clearcuts. Two more trees of equal size are still alive on our property; both are clear without branching for 50 feet. I'm waiting for another drought or hurricane to take them down.
View image in gallery
Here are two more fun pictures. Here's a big Sycamore I took down 2 years ago. It died because its roots were damaged when a land conservation group rerouted a stream nearby, cutting off its water supply. It measured 5 and 1/2 feet in diameter at breast height. Solid as a rock. Sycamore rarely gets this big because it usually rots at the base and dies. This tree was so big I had to eighth the logs rather then quartering them. I recovered 1500 bdft. of 20" wide quartered (actually eighth) sycamore boards from the 4 main logs.
scsmith42
Scott Smith
Here are two more fun pictures. Here's a big Sycamore I took down 2 years ago. It died because its roots were damaged when a land conservation group rerouted a stream nearby, cutting off its water supply. It measured 5 and 1/2 feet in diameter at breast height. Solid as a rock. Sycamore rarely gets this big because it usually rots at the base and dies. This tree was so big I had to eighth the logs rather then quartering them. I recovered 1500 bdft. of 20" wide quartered (actually eighth) sycamore boards from the 4 main logs.​
Bye,​
Paul​
Paul, welcome to NCWW! What a GREAT first post! I'm envious over those wide QS Sycamore boards! Thanks much for the pix too.
When you have a moment, please post a thread introducing yourself.
Regards,
Kyle
Kyle Edwards
Those are some nice trees. There are 3-4 just like that on the corner of our farm that are still kickin' so they get to keep on keepin' on. This Pine was actually from a clearcut in Lincolnton.
Super Sycamore..Got my eyeball on one similar if it starts to look a tad ill.
Dusty Sawyer
My FIL was born in 1922 and he grew up in western NY. When he was a boy he had an older gent for a neighbor who told him that it was not uncommon to see pine trees that scaled 3' at 90 in the air floating down the Erie Canal to a mill. I cannot imagine what they looked like as a standing forest - now that is something I wish I had the privilege to have witnessed.
Hope you have the best of luck with the yield and with the seasoning ...
I grew up in the same area and used to bike along the Erie Canal as a kid. From what I understand there is a fair living still to be made along the Canal as well as some of the great lakes by dive-locating and salvaging some of those logs. Now that's what I call hard core lumbering.
