My first segmented project (Yikes!)
nsawyer12
Nate
Started a project for a co-worker of mine who just got married. Her and her new husband are both from China so I thought it would be fitting to make something with Chinese tradition.
Soooo, I have started my first segemented bowl. The segmented blank is 12 x 12 x 3 using Padauk for the characters and Ash for the filler. The symbols means "Double Happiness".
I feel like I am in over my head and hope that it comes out OK. I made 95% of the cuts on my miter saw and still have some significant gaps. Will probably be sanding the edges to true them up and make everything fit up better. I am planning on using Titebond-II glue to bond everything together.
b4man
Barbara
WoW!:icon_thum
It's gonna be beautiful and I'm so impressed with your sentiment toward trying to bring a little of their culture into this project. Can't wait to see more pix of your progress.
MrAudio815
Matthew
This is going to be very interesting for sure and I can't wait to see the finished product and any other pic's along the way.
EdMorgano
Ed
NSayer12,
I have a question. What you are showing in the picture is a flat blank. How are you going to make it into a round bowl? Is that going to be the bottom of the bowl, is it going to be a shallow bowl or what?
nsawyer12
Nate
NSayer12,
Ed,
The blank will be 12 x 12 x 3 when it is all glued together. After that I will put it on the band saw and cut it to a circular shape, then mount and turn it. Since it is only 3 inches deep, my plan is to make a shallow bowl/plate. The picture you see is what the inside of the bowl will look like.
MrAudio815
Matthew
Nate,
Is the grain all going the same direction? Just a thought. Don't want it working against itself later with wood movement.
nsawyer12
Nate
Nate,
Matthew,
There are a few pieces that are turned 90 degrees from the rest. I hope it won't cause me any issues, but I honestly did not think about that till you mentioned it.
