Mounting tankless water heater to a vinyl sided building
MarkE
Administrator
As discussed in this thread, we are going to put in a propane tankless hot water heater.
Our house has vinyl siding and the heater we are getting is an outdoor unit.
What is the best way to attach this tankless hot water heater to the outside wall of our vinyl sided house? Do I need to cut out some of the siding and mount to the sheathing? Or just add some kind of spacers (PT pine) on top of the siding? Or maybe sink a 4x4 post into the ground and mount the heater to that?
What would you do?
Guy in Paradise
Guy Belleman
Re: Mounting stuff to a vinyl sided building
I am not an expert, I just know what I have seen. You might want to explain what type of unit you have a little more.
I have lived overseas many years where tankless water heaters have been the standard for a long time. The houses are generally concrete or block and the heater is mounted right on the wall. The heaters generally run on kerosene and that tank is often on a stand so that the fuel gravity feeds to the burner.
In the USA, there seems to many various models, and the manufacturer generally provides guidance on how to mount to various walls, or even ground mount on a concrete pad and stand. Think I would call your local area construction codes office and ask. They should be able to provide some input. Cutting into the vinyl would reduce the potential heat contact, but will increase the chance of weather intrusion, and ultimately some real problems. Maybe bolting an exterior plate onto the wall and then mounting the heater on that might be the best, then there are only four, or so, bolt holes into the siding. Think I would still call the codes folks. Maybe even contact your house insurance coverage company and ask them, I am sure they would be interested to look it up for you. I would bet that the propane tank(s) have to be a certain distance away from the heater, and depending on size, from the house as well.
It is good that you are thinking about this instead of jumping right in and installing it in potential violation of any guidance that may invalidate any future problems. Good luck.
Guy in Paradise
Guy Belleman
Just read your other thread on the decisions and thoughts on an electric tankless heater. Lots of good information there. Glad you have focused on propane. In the end, it should be most painless installation. Sorry you have to go through the process of returning those electric units. Again, good luck with the project. Maybe you can write a book afterwards and recoup some of the expense. Getting all of the information in one source would be beneficial to many homeowners. I want a copy.
merrill77
Master Scrap Maker
If it were me, I wouldn't mount it through the vinyl siding. Vinyl siding is easy to break and hard to fix. I'd find or create something else to mount it to.
Joe Scharle
Mine's mounted directly to brick, but I'm sure they provide a standoff mounting plate.
dave "dhi"
Dave
Cut out siding and flash ur OSB board with a water proof membrane or galvanized flashing be then run a J-channel around ur box! Do NOT attach directly to vinyl! not level and now water can penetrate behind vinyl and you'll never know it. Whats bad about vinyl, can't see water damage behind it!:elvis:
FredP
Fred
what dave said and in addition vinyl sideing moves a LOT! if you attach to it and restrict this movement it will pop right off the house! DAMHIKT....:gar-Bi
MarkE
MarkE
Administrator
I have tried to find more information on exactly how to mount this heater and I am coming up empty. I have never worked with vinyl siding before, so this is all new to me.
If anyone can point me to a good resource on how to get this done the right way, I can probably do it myself. So far I have found nothing.
Maybe I would be better off just having someone else get this thing mounted. Is there anyone here that wants the job? Send me a PM... Please.
gfernandez
Gonzalo
This may be an obvious question, but have you tried calling the manufacturer and seeing what they recommend?
MarkE
MarkE
Administrator
I have contacted the manufacturer. They say that the heater can be mounted with zero clearance on the back side. I asked specifically about mounting to vinyl siding. They will only say that is has to be mounted 'securely'. They do/will not give any additional instruction specific to different types of siding. They suggested that I contact a professional installer.
ScottM
Not sure of what the weight is you are talking about but I have had good luck attaching things to vinyl using clear silicone. Make sure it is the 100% silicone.
MarkE
MarkE
Administrator
I thought the heater weighed around 40-45 lbs. It actually weighs around 80 lbs.
It was delivered yesterday. Unfortunately, A natural gas unit arrived instead of a propane unit. I have to call the company today to get that sorted out.
I have had conversations with FredP and he is going to do the mounting.
dave "dhi"
Dave
Find stud of house, cut out siding and lag to stud! Refer to my previous posts! Have installed numerous things to vinyl homes !!! Self-employed contractor. Dave
MarkE
MarkE
Administrator
Finally got this thing up and running.
FredP came by and got it mounted to the building. After talking with the propane service guy and the plumber I ended up moving it about 12" higher on the wall. After watching Fred, I had enough confidence to do it myself.
Had to run a new wire for the electric. Put in an on/off switch and added a duplex outlet. The outlet can be used for a sump pump to flush the heater with vinegar once a year. Also ran wire for the remote thermostat to the garage. Mounted that just outside the door to the house.
The propane guy came by a couple of weeks ago, but he did not have the 3/4" pipe and risers needed. He got the parts and did the install on Monday. The plumber(s) got the water hooked up on Wednesday. Now we just have to experiment with the temperature to find the best setting. I had it set to 110 degrees, which seemed a little high for a shower, so I set it back to 108. LOML thought that 108 was not warm enough for washing hands/dishes etc, so it is back to 110. We'll have to see how that works.
MarkE
MarkE
Administrator
We have always had our water heaters set to 120 degrees as well. Both tank and the tankless we had in our last house. You kind of have to set it to at least 120+ with a tank heater, so you don't run out of hot water.
It just seems counterintuitive to heat the water up to 120, then add cold water to that to cool it down for a shower. We don't need 120 degree water for anything else. The dishwasher can heat water to whatever temp it needs. Most of our laundry is washed using cold water. If we need warm for the laundry, we can just set the temp to hot. If we really need hot for the laundry, the heater can be set to 120 (or up to 140) until that load of laundry is done.
Can't think of a single reason to heat the water any higher than what we will use it at.
bobby g
Bob
Nice and neat looking Mark. So what did Fred do about the siding?
bobby g
SeanStuart
SeanStuart
I was going to suggest you call your county or local planning and inspection dept. to find out what is code. Looks like you put in on top of the siding?
What did the unit cost, if you don't mind sharing.
Joe Scharle
Personally, I like all the water force I can get by mixing hot and cold. And I do think the dishwasher's coil has to work harder and draw more power for colder water. JMTCW
MarkE
MarkE
Administrator
bobby g
Fred cut 1-1/2" holes in the siding with a hole saw. In the center of the holes he screwed hangar bolts into the wall stud. The hangar bolts had wood threads on one side and machine threads on the other. The hangar bolts keep the heater <1/4" away from the siding. On each side of the hangar bolts he added 3/8" lag bolts that screw into the osb. These were mainly just to keep the heater from rocking. All of the holes in the siding were filled in with silicone caulk.
