Mesquite HF
Nate Davey
Nate
This is a 5 1/2" tall by 3" wide mesquite hollow form with a holly finial. The side by side is a before and after dying to illustrate the difference black can make in a finial. The HF is finished with lots of coats of WOP. Thanks for looking thoughts and critique appreciated.
eyekode
Salem
I like the form and the finial. Oh and the wood georgous!
How thin do you turn his type of vessel?
Salem
Nate Davey
Nate
Thanks Salem, the walls are less than 1/4" save the bottom which is a bit thicker for ballast. Mesquite is an absolute joy to work with wet, heard horror stories about how hard it is when dry
CaptnA
Andy
I love turning mesquite!
I've only had two pieces that were wet, and a good bit that was dry. And dry, it turns well and affords
you plenty of opportunity to hone your sharpening skills...
Beautiful wood and I tend to save my shavings.
Nice job on your piece.
The black I liked much better than the plain holly.
scsmith42
Scott Smith
Looks great Nate! One question - how do you turn such a thin finial w/o having it grenade on you?
Nate Davey
Nate
Hey Scott,
Sharp tools, using my finger behind the piece as I cut to "push back" against the tool and light cuts. Might try and swing up your way next week if you're going to be around. I'll drop off a good DVD for you.
