Re: Marking Gauge Workshop
Here are the pieces I came home with (had to leave early):
The oak one had some nasty checks in it so I filled with transtint colored epoxy:
Next I routed 1/8" square off of the corners of the beam:
And used the beam to mark the groove to remove from the head:
Next I drilled the hole in the head. I used a center punch and the shaft to accurately mark the location:
An egg beater drill works great for countersinks:
I threaded the hole as recommended by Mike and used a CA adhesive to set the screw.
And the final product (bradford pear and crazy oak scrap from Scott Smith):
In operation they work very smoothly and lock down tight. The design is also very aesthetically pleasing and the shape fits the hand naturally. The only thing I would do differently is the blade. It is too long and flimsy and can deflect and follow the grain when you need it to cut straight. I will be replacing them with jig saw blades ground down.
Thanks again for the workshop Mike and Bill! And thanks for the design work Mike!
