Re: Marking Gauge Workshop
I can do the 8th, and I can prepay also!
I got in the parts today. Starting to assemble kits.
For you guys taking the workshop, do you want to drill and tap the brass parts or should I go ahead and do that?
I had planned to cut the strip, drill four holes, countersink them then cut the blade holder, drill and tap the screw hole for it. The cross drilled hole for the holding pin has to be done after it is glued. It just a matter of speeding up the workshop or doing the whole thing yourself.
It's not crucial that I do every step on my own. I would like to see each step done if possible though. Ultimately this will be your call. I am looking forward to the workshop.
