Making a Fence for Delta 14 Bandsaw
Flute Maker
I have a 14 Delta bandsaw with the riser block. I just wanting some ideas on making a simple fence. I dont use it a lot but want something a little better than clamping a board to the table. TIA
creasman
I upgraded the fence on my Delta contractor's table saw to an Incra fence. I kept the old fence/rails and cut these down to use on my band saw (same model as yours -- 14" Delta w/riser). It works perfect. Perhaps you could find someone who has upgraded their table saw fence and wants to get rid of the old one.
gmakra
George
There are magnetic fences that work grest. They can be positioned any were on the table and you dont have to have any hardware attached to the saw.
I have the Carter and Magswitch both are good fences.
There are some good high quality options available, and I'm sure they would all do a great job. But that quality usually comes w/ a pretty hefty price. If you just want to cut a straight line on a board and don't mind a low tech/low price solution, try a magnetic tool holder. I use something like this on my smaller band saw when I just want a quick cut. Plop it down close to where you want it, then use light taps to fine tune it.
Flute Maker
Flute Maker
Now I like the Delta contractor saw fence that is repurposed and the Kreg ones are great too but right now I can easily go the magnetic route until I decide whether or not to spend some $.....A bonus I have some magnets in shop that will work..... I actually have one just like Bill suggested plus a magswitch one also that is unused at the time....All that metal base on the bandsaw and I didnt think about a magnet lol! Thanks guys!
Check out the band saw fence tip over at Woodsmith. Go to Woodsmith.com, tips and techniques, band saw fence
