Thanks Mike! Hopefully it will be a fun project.Considering wood movement and if you plan to use two solid planks of wood laminated together then I would orient the grain the same way.
This should also help to blend the two pieces to look more like one large piece.
As an added design element you may consider a third thin plank of a contrasting colored wood.
