Greetings fellow members! I cut my first pocket holes today using the Kreg K3 jig, and I have a question concerning my results. I am using 1/2 MDF (I know I may be asking too much of this jig with the material choice and size) to box a portion of a new mantle shelf. I set the jig up according to the directions for 1/2" thick material, but the exit holes of the final product do not exit along the center of the edge of the boards. The result was having the 1" screws bust through, albeit narrowly, the exterior side of my 90 degree joint. :BangHead:
Has anyone had any issue with the drilling angle when using thin material? I used the base unit after securing it to a piece of 3/4" plywood that was clamped to my work surface. I took my time and made sure the pieces sat flush with the base when clamping them into the jig. The MDF measures a full 1/2". I drilled 16 holes, each having the same result. My apologies for not supplying photos. Maybe someone can make sense of my description. :icon_scra Any help would be greatly appreciated.
