Interesting Article on Factory Made Lock Miters from 1930's
Mark Fogleman
This is cool:
1/128" of separation at the end of the joint with a moisture change from 5% to 13% ain't shabby.
http://www.thisiscarpentry.com/2010/04/30/curtis-mitertite-joint/
Glennbear
Glenn
Definitely interesting, I am betting the author and his associates never had occasion to use a molding head on a tablesaw. I use an old Craftsman head and by using a straight cutter in conjunction with my miter gauge I believe I could easily duplicate the joint. Younger woodworkers see a dado or rabbet and do not consider the molding heads. :wsmile:
Mark Fogleman
Mark Fogleman
Definitely a joint to consider when trimming out Saunas and Steam rooms. A small version would work well with Cigar Humidors.
