I've cut a two-way taper leg, but now I'm need of a four-way taper. Any tips or suggestions on how to pull this off safely?
In my assumption, you want a leg that is tapered on one end on all four sides, resulting in a smaller footprint...that being said, wouldn't you set up your taper jig, and just keep rotating the 'square' end of the leg and making a pass on your table saw until all sides are tapered? Conceptually done at my desk with a pen on a piece of paper making passes on a line I drew on the paper, you would never need to re-align or reposition the jig, just rotate the stock 4 times.
I cut 4-way tapers with a bandsaw and a hand plane. Mark the taper, cut near the line with the bandsaw and plane to the lines with a sharp handplane (I use a low angle jack). You'll have to re-mark the taper lines on the new face after each cut on the bandsaw. To facilitate this, I mark the dimensions of the small end on the bottom end grain with 4 intersecting lines - think tic-tac-toe. after each cut it's easy to re-mark the taper using the tic-tac-toe lines as a reference. Thin shavings with a sharp hand plane gives you lots of control as you approach the taper lines. Even if you overshoot a little, small variations in the dimensions of the finished leg are not noticeable.
