I am building some cherry night stands and I am at a point where I am ready to finish them. I have applied two coats of Arm R Seal from General finishes to a test piece.
The picture above is a piece of the cherry is unfinished.
The picture above is a piece of cherry that has two coats of Arm R Seal. The first coat was cut 50/50 with mineral spirits. I would like to have the piece a bit darker while still making the grain come out as much as possible.
What can I do to make it just a bit darker? Will the cherry get darker with time? Can I add some dye to it? If so, can you offer some suggestions?
