Furniture Commission
Woodmolds
Tony
Cherry Dresser built to customers dimensions.
30" wide X 15" depth X 48" height.
Primary wood is Cherry, secondary is poplar.
18" X 24"(mirror size) mirror frame. Cherry
Tony two beautiful pieces.
I am Speechless! (and it takes a lot ;))
Roy G
Roy
I don't believe I have ever seen cherry with that much figure. That chest is just absolutely awesome.
Roy G
CrealBilly
Man that is one looker...
I'm a bit confused on the use of miter joints on the carcass though - never seen that before. Could you please explain what holds the bottom legs / trim and top / trim in place
Thanks
Very nice job. Beautiful wood. Details of construction would be nice.
My guess is the bottom legs are indeed mitered together, probably with a spline. I've made a few feet like that and cut them on a bandsaw. Those look tall for that. The traditional way is to make a molding and then cut the pieces from it. The moldings at the top and bottom I suspect are applied. I think it's basically a box with spacers at the top and bottom that moldings are applied to and the top is fastened to. But I didn't build it so that is a guess.
golfdad
Co-director of Outreach
Dirk
Tony that is awesome. Great figure. What did you use for a finish?
Great job, Tony. The curly Cherry drawer fronts really make it stand out. Same question as Jeremy: solid wood or veneer? Is the design original or did you use existing plans? Would love to see some of the WIP pics, if you have them.
Woodmolds
Tony
Thanks
There are no miter joints on the carcass. The drawer blades are dovetail dadoed into the sides.
The mold at the top & bottom is nailed into the frame behind it. The legs are screwed from the bottom. The top is screwed to the frame below it. I don't think I have a picture of the leg. I may have one similar here I can photograph if you want me to.
Tony
Woodmolds
Tony
Pretty much spot on, except the leg material was run in linear pcs on the molder first then cut out, then mitered. The legs are pretty tall at 5-1/2", but I felt they looked appropriate given the 48" OAH.
Woodmolds
Tony
The mold and leg profiles are from a Thomas Elfe piece. The size was specified by the client. I used five drawers because I felt the height needed it to look proportional.
Thanks everyone for the comments, Tony
