Man that is one looker...
I'm a bit confused on the use of miter joints on the carcass though - never seen that before. Could you please explain what holds the bottom legs / trim and top / trim in place
Thanks
Very nice job. Beautiful wood. Details of construction would be nice.
My guess is the bottom legs are indeed mitered together, probably with a spline. I've made a few feet like that and cut them on a bandsaw. Those look tall for that. The traditional way is to make a molding and then cut the pieces from it. The moldings at the top and bottom I suspect are applied. I think it's basically a box with spacers at the top and bottom that moldings are applied to and the top is fastened to. But I didn't build it so that is a guess.
That looks awesome. Are the drawer fronts solid wood?
Tony that is awesome. Great figure. What did you use for a finish?
Great job, Tony. The curly Cherry drawer fronts really make it stand out. Same question as Jeremy: solid wood or veneer? Is the design original or did you use existing plans? Would love to see some of the WIP pics, if you have them.
