Drying Pine Pitch
scsmith42
Scott Smith
Gary, I know of no reason why it could not be applied to the bowl blank.
When exposed to heat, pine sap will crystalize at the highest temperature that it's exposed to. 160 - 180F is the standard, as this is hot enough to keep the crystalized pitch from turning back soft in most environments. When it is exposed to heat, as you get close to the temp that the pitch was set at, it will start de-crystalizing and become soft again.
For an interior use, such as a bowl, you could probably get away with a lower temp, but you may have some problems with the heat from turning.
