Drill Press Cabinet
Jeremy Scuteri
Jeremy
I finally finished my Drill Press Cabinet. It was mostly based on the Woodsmith Shop design shown below:
187475
First the base was built using poplar and plywood.
187477
187478
Next was a platform to go over the mobile base. Both pieces are on wheels.
187479
187480
187481
187482
187483
187484
187485
187486
187487
One of the modifications is a cabinet with a door that has "depth" for storage. This was a suggestion from Charlie. I'm glad I did it.
187488
187489
187490
Cabinets set in place on top of the platform.
187491
Next was time to paint. I used Dirk's (golfdad) painting recipe which was Sherwin William Pro Classic paint, Floetrol and water. Getting a good paint finish wasn't as easy as I thought it would be.
187492
187493
Trying to hide some defects/seams with filler before the next coat of paint.
187494
187495
187497
187496
Solid wood edge banding on the cabinet faces.
187498
187499
187500
Looks like there is a 25 image limit for a post.....
Jeremy Scuteri
Jeremy
Next was the top.
187501
187502
Edge banding.
187505
Oops. A little mistake.
187504
That's better.
187506
The piano hinge left a bigger gap that I was expecting. It will only be visible from the back since it is covered by the top and the gap doesn't exist in the front.
187507
Screwing the cabinets to each other and the platform.
187508
Finish on the top. Looks pretty.
187509
The top in place.
187510
Fitting a door in place.
187511
Marking for the hinges.
187512
187513
My smallest router doesn't fit.....
187514
Hand tools to the rescue.
187515
187516
187517
Using a screw to make a dimple to locate where the metal disc should be mounted to mate with the magnet.
187518
Dimple created.
187519
187520
187521
Coming along.
187522
187523
Time to build some drawers:
187524
187525
Jeremy Scuteri
Jeremy
Drawers are done.
187526
Setup to locate and mount the drawer slides to the drawers:
187527
187528
187529
Drawers installed:
187530
Drawer fronts
187531
Method to flush trim edge banding with the tablesaw.
187532
Making sure all the drawer fronts fit in place.
187533
A small repair with wood filler and dye.
187534
Applying finish.
187535
Drawer front install.
187536
Installed drawer pulls.
187537
Just need to load it up with stuff at this point. I like the mix of wood and paint.
187538
187539
187540
187541
187542
Wow, what a gorgeous cabinet. And you're right, it looks a lot like the original from Woodsmith shop :rolleyes::D:D:D
Beautiful execution.
Superb job Jeremy and a very nice Photo Essay of your build. Way too elegant for my shop, but I also like to paint my cabinets to give them a better look. I have a Floor model delta and most of the hardware to build one like yours; all I need is a kick in the butt!
Graywolf
Board of Directors, President
Richard
Jeremy, that turned out beautiful, I look forward to seeing it next month!
Barry W
Co-Director of Outreach
Barry
Jeremy, beautiful detail work! Thanks for sharing.
drw
Donn
Jeremy, that is one heck of a beautiful cabinet and your pictures of the details associated with the build are awesome...all of the details and precision made me feel like I was once again looking a "Norm's" craftsmanship!
GREAT job Jeremy! and I would have to say I think it is better than "Norm's" craftsmanship! but with all that work - why did you buy handles? I would have like to see what you came up with!!!
Jeremy Scuteri
Jeremy
Thank you everyone for the kind comments. It was a fun project and a nice way to get back into the swing of things after taking time off to build the workshop.
Jeremy Scuteri
Jeremy
For whatever reason making your own handles seems daunting to me. I do kind of like the look of the metal hardware at the same time. Plus it is super convenient. :)
