Thanks guys.
Tom I did not take any WIP pics. Kids took he camera but I got one for fathers day.
The panels are "floating" panels secured with/by Domino loose tenons. Also the frame joints are with the Domino loose tenons. Worked really well.
I dovetailed the drawers, half blind using a WOODHAVEN jig which I like but I do not have anything to compare it to. The drawer box material is a prefinished ply from NC Hardwood. The routed dove tail were not as smooth in the 3/8 ply. It splintered a lot. The lock joint may have been better to use with that material.
I did use he Blum under drawer slides. I am not so excited with this product. It hooks in the back through a hole in the back of the drawer. In the front there is a spring loaded catch in a locking device that you attach to the underside of the drawer. They are "self closing", if the slide gets three inches form being closed, a spring takes it the rest of the way for closing.
I have used ball bearing slides from CS Hardware that are much cheaper, open 110% and are rated @ 100 lbs. They are easier to install, and it is easier to remove and insert the drawer.
I would lie to get other insights on such issues so I can get smarter.
