Double Refined MDF Source
Dbush714
DB
Martin et al,
I picked up 5 sheets of 30mm and 1 25mm black today. (I don’t think they have too much left of anything else at this point.). Kevin is the guy to check with as Martin indicated earlier.
Unfortunately we didn’t get a chance to see the operation that Martin described, but it’s a big place for sure!
Please note if you are able to secure some, it is extremely dense and heavy! I can’t wait to see how it mills up!
Martin - thanks again for all the work in locating it (and making me aware of Dennis’ YouTube page). Much appreciated!
tvrgeek
Anyone have a scrap I can look at? I am curious for use in speaker cabinets. Regular MDF is pretty "dead" which is good, but not quit as rigid as I might like, epically for front baffles which are hard to brace.
Martin Roper
Martin
Scott, I should have some when I finish my workbench over the next few days.
AnotherJim
I've been reading this thread, after enjoying the hooked-on-wood YouTube videos. I also want to make the guy's workbench-table. What I don't get is, why use MDF? Wouldn't a sheet of 3/4" hardwood plywood be more durable? It's also readily available (Lowe's/Home Depot), and cheaper (ca. $80 vs. $100), although in the long run, the cost is immaterial to the effort to build and long use of the bench. The MDF looks nicely planar, but a sheet of maple plywood could be sanded to be equivalent (that's kind of a question in it's own right)?
Martin Roper
Martin
Dennis built the entire frame of his table out of plywood. Only the top of his bench is Valchromat. I think he chose it because the surface is much harder than plywood. This stuff does mill up very cleanly, much better than regular MDF or plywood.
tvrgeek
Knuckle test suggests it is not as "dead" as cheap MDF, but I think it would be a much better material for speaker front baffles. As my next design will have curved sides, I think regular MDF is a better material.
Bming1
Brandon
Part of the reason is the aesthetics, I’m sure. The color pigments are added into the resin+fiber mix, so the Valchromat retains its color throughout, instead of being a surface finish. It also feels incredibly hard and is moisture resistant, as well as supposedly being easier on your cutting tools than MDF (dunno how it compares to plywood).
wolfsburged
Bumping this back up from the dead - Martin or anyone else who got some of the Valchromat, what is your impression a year later? Did you ever build the table top with it and can share some observations?
Martin Roper
Martin
I built a MFT-style workbench with it that turned out well. It machines well and is harder than regular MDF.
I'm going to make some Shaker drawer fronts with what I have left.
kooshball
I called Horizon Forest Products and they have better grade mdf than the standard home improvement stores. I'll try to swing by there this week and get some. Thanks for the recommendation!!
Double refined mdf is a better grade mdf than the home improvement stores. That's really the only name I've seen referenced when looking for better quality. At this HFP store, it's called MDF Trupan Plus. I have a cnc and want better finishes when cutting mdf.
Back in the day I got high-grade mdf for a speaker build from Wurth Group in Raleigh. They also had really nice Baltic birch if I remember correctly.
