I'm currently working on a changing table, based on a plan from Amateur Woodworker with various modifications. It is a dresser design so it'll be useful beyond having a baby in diapers. A picture from the plans (not mine):
I don't want to paint it like the original plans, so i decided to go with soft maple. I didn't have a planer when i started this so i got it surfaced from Wall Lumber. It was pretty flat when i got it, though there was a bit of tear out i'll have to deal with. I spent a bit of time laying out the cuts to get the best pieces for the most visible parts and match grain patterns. The wood with the cuts marked in chalk:
Next i ripped most of the pieces to width and rough cut to length, and got a couple of panels glued up.
I was just starting to pick up some speed, and then my daughter arrived a month early! This was a little over four years ago, and due to moving, higher priority projects, and general lack of time, i hadn't touched it beyond stacking in my lumber rack since she was born.
Now i have another child due September 4th, so i get another chance to finish it. :eusa_danc I've worked on it a little bit in the last month, but up until now i've been busy with other projects around the house. I'm finally finished those up, so now i can concentrate on the changing table. I only get a couple of hours to work on it at night after my daughter goes to bed and maybe half an hour at lunch if there is no outside work to do, so it is going to be a tight race. I'm hoping this one is more cooperative than my daughter and waits a while longer to come. :eusa_pray Here is where i'm at now:
I'll try to post as i have visible progress, and i'm sure i'll have some questions along the way.
